Clop Ransomware Decryoptor Help
hi guys, my computer has been affected by clop ransomware, is there any decryptor to recover my data? i don’t have any backups
thanks
Hey, sorry to hear you’re dealing with Clop ransomware—it’s a nasty one. Unfortunately, as of now, there’s no public decryptor available for Clop, as it uses strong encryption that hasn’t been cracked.
Since you don’t have backups, your options are pretty limited. Here’s what you can try:
  1. Check for Shadow Copies – Sometimes, Windows keeps old versions of your files. Open Command Prompt as admin and run:
    vssadmin list shadows
    If there are any, you might be able to restore files.
  2. Use Data Recovery Software – While it won’t decrypt the files, tools like Recuva or EaseUS might recover deleted originals if they weren’t fully overwritten.
  3. Look for a Decryptor – Keep an eye on NoMoreRansom.org in case a decryptor is released in the future.
  4. Avoid Paying the Ransom – There’s no guarantee they’ll give you the key, and it only funds more attacks.
  5. Check for Cleanup Guides – Even if you can’t decrypt, you should remove the ransomware to prevent further damage. Malwarebytes or HitmanPro can help.
I know this is frustrating, but let me know if you need any help with the steps. Hope you manage to recover something!
Thanks for the reply, ill keep these things in mind.
No Problem, if you have any more doubts just post here
Did you solve this issue? I am also facing issue with Cl0p ransomware.
