I have a fresh install of minecraft and i keep getting the same crash report. iv tried reinstalling minecraft, and display drivers. heres the crash report.
---- Minecraft Crash Report ----
// Why did you do that?
Time: 1/25/17 7:05 PM
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bes.ap(SourceFile:600)
at bes.an(SourceFile:436)
at bes.a(SourceFile:383)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
– Head –
Thread: Client thread
Stacktrace:
– Initialization –
Details:
Stacktrace:
– System Details –
Details:
Minecraft Version: 1.11.2
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot™ 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 50444528 bytes (48 MB) / 151658496 bytes (144 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.11.2
LWJGL: 2.9.4
OpenGL: ERROR RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ERROR NullPointerException: null
Profiler Position: N/A (disabled)
CPU:
thanks to anyone that can help.
