Hey guys I have a dell t110 1st generation. I need to know what motherboard upgrade is need?
Sent from my 831C using Tapatalk
Motherboard upgrade depends on your needs. If you are a hard core gamer then you should get a gaming grade one.
I wanted a I need a gaming one
Which is the processor you want to use?
Dual core Intel core i3 processor 500 Series
Again there is i3- 560, 550, 540 and 530 can you be more specific
OK so I downloaded a file that tells u the specs the r 4 processors but all are different
When I get home I’ll take pictures
Sure that will help more over install CPUZ software and give a screenshot of it. It will give all the specifications of your PC
https://uploads.tapatalk-cdn.com/20170125/c4ae3d94946c88cf930ab22265e0bb38.jpg
O my God
https://uploads.tapatalk-cdn.com/20170125/4738bc66baec67a7a0581cac0d91276d.jpg
It come out blurry
https://uploads.tapatalk-cdn.com/20170125/4e4a3b59ef0168137ca48c279f3bb531.jpg
Dell T110 is a server grade machine it’s not meant for gaming. I would advise you to build a gaming PC.
Better get the latest kabylake i5 or i7 with a GTX 1050 or higher for playing modern games without frame drops.
Thanks
I need to know what mother board upgrade do I need for it
Upgrading the motherboard alone won’t do anything. Assemble a new PC
OK I am going to OK get the a new CPU, gpu, and motherboard and ram
