Pendrive not detected
[SIZE=5]My pendrive is not detected by the system. I was copying a movie file to the pendrive and at the same time tried to delete two files from the drive. The deletion task was on pending and after the copying was done, I got an error message and i clicked “skip” ( My bad i didnt read what was the error :expressionless:). After that the window was closed and from there my pendrive isnt recognised by the system.
I plugged it into a different computer and the result was same. Is there any way to make it usable again?[/SIZE]
No, there is not any way to make your pen drive usable. I also have a problem with my pen drive I do many efforts by changing raw to compatible or by plugged into different computers but I can’t get any result.
Most probably the pen drove might be corrupt or try plugging in the pendrive to the another device
Mostly got corrupted
if the pen drive is detected in device manager , try formatting using “HP USB DISK STORAGE FORMAT TOOL”. if format is successful then pen drive will be good as new to use.
