Ryzen 7 3800xt overheating! Help please
As the title says, my CPU is running much too hot. I simply can’t game on it as it is, it has peaked 100 c just from launching games (Kingdom Come: Deliverance was used to test) and sits idly between the high 60’s and mid-80’s. I’m trying to work out what the issue is.
I’ve ordered some more case fans, and new thermal paste in case the paste I used was low quality so I’m hoping these changes will fix my issues.
At this point, I’m assuming it has to be one of three things. The CPU cooler is improperly mounted (RGB Wraith Prism, and it doesn’t seem to be improperly mounted), the thermal paste was improperly applied or was of poor quality, or that there is not enough airflow in the case (Only one fan for the case currently, but I’ve ordered three more).
With this subreddits endless collective understanding for all things PC, I’m hoping to get some clarification that I’m on the right path.
For the record, my ryzen 5 2600 was in this exact build (but using a wraith stealth cooler) and NEVER reached these worrying temperatures. My motherboard is a MAG b550m mortar.
Ya something is wrong. I absolutely blame ur cpu cooler mounting. Somehow it’s not tight.
Im a noob with these things so please help me with this with baby steps
Just twist the cooler side to side to see how loss it feels. It will still move a bit when it’s tight but if it’s very easy then it’s wrong. @hebergem you got any words mate?
That cooler. So, the mounting brackets need to be checked. Specifically, they need to be TIGHT. Then you need BOTH clips to he VERY tightly in place. You should also consider applying fresh thermal paste. Also, check the clips on the side, they might not be properly mounted to the cooler itself.
I feel like an idiot! The cooler wasn’t even clipped in properly. Sorry for wasting your time, and I appreciate the help immensely :smiley:
Its fine LOL i have made mistakes worst than this.
[IMG alt=“Happy Shirley Temple GIF”]https://media4.giphy.com/media/12PIT4DOj6Tgek/200.gif
Yes, never say idiot yourself because everyone is fresher when they start. Always be ready to learn and ask questions. Hope you understand my point.
