What 60$ cpu air cooler should I get?
I want to get the best cooling for my i5 6600k and i have a budget around 60$
You can check this one here. I won’t recommend using a cheap water cooler as it will be less efficient. You can get a great air cooler for this price and that can perform well.
Okay i know that but for my current build wanna use a water cooler. The one you suggested seems nice. Thanks!
Corsair H60 or H80i if u can find one for that price
I would go with an air cooler for this budget!
@schoolster , @redblade what if I choose an air cooler for this price?
U could do that as well,like a cm212x or noctua cooler(If u r okay with the colour)
I don’t need much fancy RGB lights, just better cooling for lower price!
Like i said before, air cooler in this price range can out perform better than water coolers.
If u want to just cool u can use stock cooler, if u want more, give me the parameters like
  1. Noise level
  2. Fan speed
  3. Temperature differential
  4. Cooling primary medium ( liquid/air )
6600k doesn’t come with a stock cooler
