Whats up with Intel Z690 Motherboard DDR4 and DDR5
Which is better DDR4 or DDR5 motherboard, I heard there latency issue with DDR5 ???
Hmm there shouldn’t be a latency issue on DDR5 when compared to DDR4
But over internet I found that DDR5 have bad latency around 40 to 60 as compare to DDR4 memory.
DDR5 should give better latency otherwise there shouldnt be a DDR5 at all. The latency issues you heard might be due to incapable motherboard chipset or something.
Yes, I think you are right I recently check the new benchmark and it was good this time.
