I want to understand which is better for developing a smart watch
For smart watch development, ESP32 is the best choice. It offers ideal features like low power consumption, built-in Bluetooth/WiFi, compact size, and sufficient processing power. Arduino is good for simple projects, while Raspberry Pi is too large and power-hungry for a wearable device. ESP32 provides the perfect balance for smart watch prototyping and development.
Depends on the project you are working on… Raspberry Pi except Pico all are SOC Microprocessors.
If you need basic IO with wifi and 2 powerful arm cores. You dont need a fully fledged OS then go with ESP32…
If the project is complicated to a point where it need a system which runs linux to make it work, then go for Raspberry Pi.
Anyway choice is yours.
thank you man !!! helped me a lot
