Solved Flash Stock Firmware on LG K8 (K350 All Models)
Arjun Chandran
Master Sergeant Rank 13
674
17,850
Awards
India
Fix "Your device is corrupted and cannot be trusted and may not work properly" error on LG K8 K350DS / K350E / K350F / K350H / K350K / K350N / K350NDS / K350TR / K350Y / K350Z. In this post, ill give simple steps to flash the stock ROM on your LG K8.
First, you will have to download the firmware KDZ file for your model. Download from the links below:
Download and install the softwares provided below to your PC:
LG UP v1.14
LGUP_Common
LG Drivers
LGUP LG K8 LG-K350Z
Instructions To Flash:
  1. Press and hold Volume Down and Power button on your phone then connect it to your PC, and the phone will go into download mode.
  2. Open LGUP on your PC.
  3. Select BIN File ( the .KDZ firmware file that you downloaded).
  4. Then click on the Start button.
  5. Wait for it to complete.
  6. Done!
  • LGUP_v1.14.3.msi.zip
  • LGUP_Common.zip
  • LG Drivers.zip
Reactions: Abhiram Shibu
