It's the same one I shared.How accurate is this?![]()
Requirements Test
Check your system requirements. Can I Run it? Test your specs and rate your gamimg PC.www.systemrequirementslab.com
This is one that I used for years! You just gotta let it scan your computer to see what gear you're running and it will tell you how well you can run a game.
ThanksIt's worked very well for me in the past! Use it as a rough guideline to see if you can run things. If its saying your gear can only just about run a game expect a bad experience. Running it at 720p might help
