To force HubSpot to sync with Salesforce, you can follow these steps:
- Log in to your HubSpot account and navigate to the HubSpot-Salesforce integration settings.
- Check if the integration is properly set up and connected between HubSpot and Salesforce.
- Verify that the objects and fields you want to sync are selected in the integration settings.
- In HubSpot, go to the specific record or object that you want to sync with Salesforce.
- Edit the record or make any necessary changes that you want to sync.
- Save the changes in HubSpot.
- HubSpot will automatically trigger a sync with Salesforce, pushing the updated data to Salesforce.
