How to Convert PST Contacts to vCard File?
alora01
Sep 29, 2023
76
1,700
Check out Advik PST to vCard Converter for seamless export of your contact details. This tool seamlessly supports PST files from Outlook 2021, 2019, and all prior versions. You can effortlessly add multiple PST files and export contacts from all of them into vCard format without any hassle.
One easy way to convert PST contacts to vCard files is to use the Aryson PST File Converter Tool for Windows. Converting a large number of emails from PST to vCard format while preserving layout. Also removed was the superfluous software. With the filter feature, you can carefully rewrite certain sentences. This useful tool makes it possible to move email clients between Thunderbird, Gmail, Office 365, Yahoo Mail, and Microsoft Outlook with ease. It works with a number of operating systems. This tool supports updates in several forms, such as PDF, EML, HTML, TXT, and DOC, which facilitates data transfer to other email systems. Its basic design facilitates a seamless transfer by making the process of altering PST files easier.
If you are looking to convert Outlook-supported PST contacts to vCard file format. Then, you can opt for BitRecover PST Contacts Converter where you can download .pst files by maintaining all meta properties. Also, you can batch add Outlook PST files in software GUI using dual options. Plus, tool gives you a facility to choose desired folder to output contacts.
Follow the below steps for conversion
  • Download & launch wizard
  • Insert Outlook contacts in software GUI
  • Select contact(s) folder from software window
  • choose a saving option
  • Browse destination path & click on convert
Converting PST to VCF File Manually
  • Launch Outlook on Microsoft.
  • Select File from the menu.
  • Select "Open & Export."
  • Tap the Import/Export icon.
  • Click Next after selecting Export to a file.
  • Click Next after selecting Comma Separated Values (Windows) in the "create a file of type" box.
  • Click Next after selecting the Contacts folder that you wish to take a backup of in the Select folder to export from the box.
  • Next, choose Browse, then type the file name and type in Press OK to save as a file.
  • Select "Finish" by clicking. The conversion from PST to VCF will right away begin. It will be displayed in the Progress box for import and export.
  • Now the file is formatted in VCF.
Users can now convert PST contacts to vCard file format without facing any problems with the help of Softaken Vcard Export Import. Any Windows OS version, new or old, can be used to get this program. The safe method didn't take a long time to convert contacts from PST to VCF. Get the latest free demo edition without paying any money.
Using the ToolsBaer For Address Book Manager Software is one simple method to convert PST contacts to vCard files. maintaining layout while converting a big number of emails from PST to vCard format. Furthermore eliminated was the unnecessary software. You can carefully rewrite select sentences using the filter option. It's compatible with many different operating systems. Its simple layout makes it easy to modify PST files, which promotes a smooth transfer. The tool is fully secure to do this task without creating any problems. Users can easily export entire PST Contacts to VCF with the help of this software. Get the free demo edition.
If you are looking for a solution to convert PST contacts to vCard file then try XConverterPro on your system. The software is able to export PST contacts in just a few simple clicks. The interface of this utility is very simple and easy to use. Both technical or non-technical users can easily convert PST contacts into vCard file without having any technical knowledge. This is a stand-alone utility which means you can extract contacts from PST file without Outlook or any other application help.
