• Zero Spam Tolerance Policy is now in effect. Any accounts posting spam will be permanently banned without warning. Learn more
Solved Two functions may give the same result or Does it??? Think before you Type!!!
Mar 6, 2017
4
2
850
26
The very first time I was taken aback when I typed in the following code I was surprised I got the following results in python inorder to solve the linear equation ax=b
#The code to solve a linear equation in python
import numpy as np
a=np.array([[1,1],[1.5,4])
b=np.array([2200,5050])
#Using the solve function in numpy
x=np.solve(a,b)
#Using the inverse of a
v=np.linalg.inv(a).dot(b)
#Now when you check both x and v values are same but when you perform x==v you will get an entirely different value
In [24]: v
Out[24]: array([ 1500., 700.])
In [25]: x
Out[25]: array([ 1500., 700.])
x==v
#The result is
array([ True, False], dtype=bool)
which is not expected as both values shown were same
what happened may be realised if you check the element values individually
In [31]: x[1]
Out[31]: 700.0
In [32]: v[1]
Out[32]: 699.99999999999977
i.e, the value of v[1] was actually only 699.99999999999977 no 700 and hence not equal. The correct answer corresponding to our linear equation is x and not v.
This is why built in functions are preferred most of the times over our own algorithms as appearances can be deceptive
Topics You Missed
