What is a softphone and how does it work?
JosieRyan
Dec 3, 2021
200
Softphone is a type of software-based phone that is used to make phone calls over the Internet. Typically it functions like a traditional telephone set that has no display, keypad or mouse control, although softphones may also support these peripherals. They are usually designed to be utilised with VoIP services which accept calls from telephones and route them over the public switched telephone network (PSTN) through the internet.
Softphones typically support a wide range of voice codecs, including G.711, GSM and iLBC, most softphones must be connected to a PC or laptop in order to function.
How does a softphone work?
Softphones behave like traditional telephone sets. In order to answer a call, pick up the receiver or press a button on your phone.
In order to dial a number, you type it into the softphone interface and press "dial". To hang up you just put down the receiver.
Of course, there is also an address book function and other common features like hold, transfer and conference calls.
  • Wow
Brackwom
May 25, 2021
95
1,750
A softphone is a piece of software that allows users to make phone calls using their computer or smartphone through the internet. It may be installed on a laptop, tablet, or smartphone, giving you access to the same high-performance and reliable connectivity as your work phone.
KERRYLOPEZ
Oct 20, 2021
15
1,550
Amazing and informative post. I have never heard about softphones.
shivam177
Jul 20, 2022
19
1,500
A softphone is a type of software-based phone that allows you to make phone calls over an internet connection through a smartphone. It helps you make telephone calls without an actual telephone. It consists of all the features of a desk phone. Softphones behave like traditional hard phones and landlines. It runs on computers and mobile devices and can be integrated across many different platforms.
