ASUS OLED Care screensaver download
Here is the screen saver that comes with ASUS OLED laptops, it looks really cool and immersive to me. You can also use it on any laptop/PC by simply downloading and installing the screen saver file.
Preview:
[ATTACH type=“full”]503[/ATTACH]
[HEADING=3]How to Install?[/HEADING]
[li]Extract the .zip file[/li][li]Right click on “OLED Care Screensaver.scr” and click on install then change the settings accordingly.[/li][/ol]
OLED Care Screensaver - tuxforums.com.zip (51.4 MB)
Here is the default wallpaper too.. If you are looking for it :smiley:
how to install ?
Follow the instructions from the post its simple
IT IS NOT A INSTALL OPTION IN ZIP FILE,
Extract the zip file then right click on the screensaver file. If you are on windows 11 clock on show more options and then select install
find the install
Well, that’s weird this might be because windows detected it as CAD file. See my screenshot, it has the install option.
[ATTACH type=“full” width=“541px” alt=“1662899300403.png”]509[/ATTACH]
Hey try copying that file to C:\Windows\System32 and then open screen saver settings and choose the Asus screen saver file
Thanks mate works neat, after download, unzip and click right button over the file ‘oled care screensaver’ and press install and works neats mate! Working neat on my asus oled after re installation of windows.
[HEADING=3]pr0ph3t[/HEADING]
[HEADING=3]georgeichim[/HEADING]
Not the original ASUS quality though, a lot of compression here on a 4K screen. I assume you recorded the screen using shadowplay or something like that?
Here’s original file, from MyASUS folder
That is not the original file. It’s a highly compressed capture from the original file.
How come? it’s located in My ASUS folder on my laptop, does ASUS put a fake?
