backup with Macrium Reflect
I did a search for backup tools and I found Macrium Reflect to back up to external Harddisk.
I need to know if Macrium has the “resume” option? As my current Laptop has a lot of files/ folders which I think it will take longer to be copied, Also can it copy the files while it in use?
I also came across another tool called Gs Richcopy 360, Did anyone try that? Is it really faster and secure? and can it copy the files while it in use?
Please advise.
I had the good luck to try Gs Richcopy 360, it does all that I need, it has rich features and works as they promised, so, please close this thread, my problem has been solved
Hmm that’s sad that no one could give any solution :frowning: Well, at least you found and shared it with the community. Thanks @Aina
@pr0ph3t Thank You :slight_smile:
