I have an Alienware laptop and sometimes I get some blue screens and before I will send it to warranty I want to make sure a clean install of windows will fix or not the problem.
Every time when I want to reinstall the windows, I’m doing it from bios because I want every file to be new.
But, some friends told me that from windows 10, I can reinstall it from setting and will do exactly the same thing but easier.
What do you think? Will be the same thing? Will a clean install be better than the standard windows reset?
