Can I run Noctua NH-U12S CPU tower cooler at full RPM?
Hey Guys,
I have Noctua NH-U12S Tower cooler, can I run it at full RPM all the time or will it damage the fan/CPU?
Why would you want to run it at full RPM all the time? The main point of getting good/better quality coolers is to reduce the noise
I’m worried about the bearings, I use 3D software most of the time so CPU/GPU will be anyway on the load, and if I render anything temps will go up and down. So thinking to keep it at full speed now.
There’s not risk at all to the CPU. The fan might wear down slightly more but better than constant ramping up and down.
Ya, I have kept mine at 100% now.
It’s fine. The only thing that can be hard on fan bearings is constant ramping up/ramping down. Holding a constant speed is totally fine
I’m worried about bearings only mainly. Hope it will be ok if the fan is at full speed.
I have mine set to 100% because I didn’t like the temps I was getting. And its running this way for more than a year now and haven’t had any issues. Just a little loud but it doesn’t bother me since I usually wear a headset
I don’t care about the noise well for now I have set it to 100%
