Capcut No internet connection. Connect to the internet and try again
I was trying out capcut and when im opening the effects panel im getting this no internet issue. How to fix this? Can a vpn solve this?
If there are no issues with your network, ie. you can use other internet services then you might be in a region where Capcut is banned. If you are from India then Capcut is banned in your country as it’s a Chinese app ( u might know why Chinese apps are banned and the story of TikTok).
But I should say that Capcut is really awesome as a Video editing app, it has lots of features and options.
Hey, don’t worry unlike TikTok, you can simply use a VPN and choose countries like Singapore or something then use Capcut just fine.
Maybe this article will help you know why you can’t access Capcut > List Of Chinese Apps Banned In India: Xiaomi Mi Browser, CapCut Part Of 47 Barred Apps
Try using a VPN mate!
im from Singapore but my capcut isn’t working
Try using a VPN and see if it solves the issue
Capcut
Hi, I’m from Iran and apparently it’s banned here as well. I’ve been using vpn recently and it worked pretty well but now no matter whichever vpn I use, when using effects I get the no connection error. I used turbo vpn, free vpn , eclipse, vpnify, super vpn. I’d appreciate telling me which vpn you use or other solutions for this issue! Thanks.
Same problem here ??‍♀️
I’m using CAPCUT on Android for video editing, and it’s very easy to use.
The likeliest reason for the “No internet connection” on CapCut is that you live in a banned country like India, Afghanistan, or Russia. If you do, you’ll need to use a VPN to circumvent the geolocation ban. You can use any free VPN for mobile, like ProtonVPN.
It’s frustrating when you’re in the middle of editing a video using CapCut Templates, and suddenly you see the message “CapCut No internet connection. Connect to the internet and try again.” ?? The reliance on internet connectivity can be a downside of using CapCut, as it limits your ability to work on projects offline. However, staying connected allows you to access a vast library of CapCut Templates and resources to enhance your editing experience. Just make sure you have a stable internet connection to avoid interruptions and keep your creative flow going!
Check your internet connection first to ensure it’s stable. Sometimes, simply restarting the app or your device can fix this issue. Using a VPN might help if the app is blocked in your region, but it’s not always a guaranteed solution. Make sure your VPN is connected to a server in a region where Capcut is available.
If you still don’t get it try another video editor. I use movavi and i’m happy with it. It’s very easy to use and has many useful features. You can find more information here about video editing software for pc .
