Cooling Pad Vs USB Vacuum Cooler for laptop, which is better?
Which cooler more suitable for laptop
Vacuum USB cooler?
or
Normal cooler pad?
Normal cooling pad can provide better cooling as it has more surface area, I don’t think that sucking hot air from a tiny USB port and exhausting it out will be practical.
Definitely, a cooling pad can do better. It will try to cool more area.
Thank you
Vacum coolers can’t do anything compared to cooling pads. Just think, how much hot air can be sucked out of a USB port?
I use a Vacuum Cooler and it cools down the CPU really fast!
