Do water coolers cause rust at all?
Just a thought and something i heard before?
Yeah they will, but i guess it will take more years than you will want to use it.
do they really give that much of an advantage of air cooling
I had water cooling before i didnt notice a huge difference
They do rust but not so soon. After all, I believe it is not regular water running through it, its some kind of coolant I guess.
You can use a liquid coolant that will not caused rust.
