I installed the WoodMart WordPress theme and when I checked the Dokan vendor dashboard some icons are not loading. How to fix this?
Try this login to the admin dashboard, go to Theme Settings > Performance > CSS > Font Awesome library and set it as Always Use.
Hope it work ![]()
Add this pice of code to the Custom CSS area:
.dokan-dashboard-wrap .fa {
font-family: 'Font Awesome 5 Free';
font-weight: 900;
This will ensure all the free Font Awesome 5 libraries are loaded.
Noo, not working ?
Nop, this also doesn’t fix it.
Hey, if the issue still hasn’;t been solved then try this solution.
On your WordPress dashboard go to Elementor > Settings > Advanced, and select Yes for the “Load Font Awesome 4 Support” option.
