Explorer.exe is always crashing.
any solution???
reinstall windows
Sent from my Redmi Note 4 using Tapatalk
[SIZE=6]Update Windows 10[/SIZE]
Once you’ve found that Windows 10 explorer.exe crashes frequently, the foremost method you can try is updating Windows 10. As Microsoft have released the fix for this problem, a system update may solve it within minutes. To run a system update in Windows 10, follow the simple steps given below.
[li]Click on Start and then select Settings.[/li][li]In the settings window, click on Update & security.[/li][li]Next, navigate to Windows Update and click on Check for updates.[/li][li]Now Windows 10 will search for updates and install them (if any). [/li][/ol]
[li][SIZE=6]Run a Disk Check[/SIZE]If the problem is still there even after the Windows 10 update or if you couldn’t update the Windows, the second method you can try is Running a Disk Check on your computer. This could fix minor problems in the system files or the hard drive. To run a disk check in Windows 10, follow the steps given below.[/li][LIST=1]
[li]Open Run command by pressing Win+R.[/li][li]Type cmd and press Enter.[/li][li]The Command Prompt window will open up.[/li][li]Type chkdsk /f on the command line and press Enter.[/li][li]Now the Task Manager window will pop up. On the startup tab, select each item and click Disable.[/li][li]Close Task Manager.[/li][li]Return to the Startup tab of the System Configuration dialog box and click OK.[/li][li]Restart the Computer.[/li][li]Now Windows will start in clean boot mode. If the problem has finally been fixed, uninstall all applications in your Windows and reinstall them. [/li][SIZE=6]Conclusion[/SIZE]
If the problem still exists, you may go for a system restore or reinstallation of your Windows. That will surely help to fix explorer.exe crashing issue in Windows 10.
[/ol]
[/LIST]
