[HELP]Need a free web hosting for wp
Now a days free web hosting is easily available but to find one with decent features and hardware is not so easy task . I’m looking for a free web hosting for wordpress (blog). I have seen and tried many but couldn’t find one which could give me free hosting as well as provide me google adsense. actually I’m noob to this so excuse if any stupidity found.!!!
You can’t get AdSense with web hosting. If you are looking for free web hosting then try ByteHost, if you are looking a cheaper web hosting then try Namecheap hosting.
then, how can I get Adsense ?.
To get AdSense, apply for it at https://www.google.com/adsense/signup and then they will review your site. If they find that your site is good enough for their Ads then they will approve you. There are two steps in approval, when you are ready to show ads they will mail you with a “Congratulation” message.
thanks bro.
:slight_smile: Good luck.
mmm i tried most of the free webhosting sites and plans, and frankly, just ended up at godaddy, i started and have always used its economy vps hosting plans , and you can get them dirt cheap if you use there promo codes, usually 84-93% discount (and there active all year long) , honestly I’ve never paid more than 10 usd yearly, and for my needs its more than enough.
Finding a free web hosting provider for WordPress with Google AdSense integration is challenging. Free hosting options often have limitations and may lack the necessary features. Consider investing in a paid hosting solution for better performance, reliability, and support. WordPress.com offers a free plan with limited monetization options. InfinityFree is a free hosting provider that supports WordPress, but manual integration of AdSense is required. However, free hosting services may have restrictions and lower quality. Paid hosting is recommended for professional websites or blogs.
