[SIZE=4]I saw that Shadow of the Tomb Raider in Dolby Atmos is listed on Dolby’s website on the page that shows the list of Dolby Atmos games. I tried the game on my PC and my audio system support Dolby (it is just 5.1) but my rear speakers are not working!
Anyone knows how I can play Shadow of the Tomb Raider with Dolby Atmos audio on my PC using speakers, not headphones!
[/SIZE]
Are u using Coaxial cable?
Sent from my RMX1851 using Tapatalk
No, I’m using optical connection
Only tomb raider causing this issue?
Realtek doesn’t give Dolby output for games anyway but games with exclusive Atmos audio should work like Metro Exodus did work for me
In windows Store there is Atmos application .I think that helps.Its paid app btw
Nop that’s from headphones and Atmos Sound systems. I think to use that ill need a Dolby supported sound card
Ooo
@Arjun Chandran Change your in game audio settings to use windows spacial audio and then configure 5.1 in windows sound control panel
will it work like that?
