I’m bored with the Instagram platform so how can I delete my Instagram account?
To permanently delete your account:
[li]Go to the [B]Delete Your Account[/B] page from a mobile browser or computer. If you’re not logged into Instagram on the web, you’ll be asked to log in first. You can’t delete your account from within the Instagram app.[/li][li]Select an option from the dropdown menu next to Why are you deleting your account? and re-enter your password. The option to permanently delete your account will only appear after you’ve selected a reason from the menu.[/li][li]Click or tap Permanently delete my account.[/li][/ol]
If you’d like to delete a different account:
[li]Click or tap the username in the top-right of the [B]Delete Your Account[/B] page.[/li][li]Click or tap https://static.xx.fbcdn.net/assets/?revision=554433395419141&name=instagram-newsettings-ios&density=1 next to the username and select Log Out.[/li][li]Log back in as the account you want to delete and follow the directions above.[/li][/ol]
Thanks now let me get rid of it ![]()
Now I have [SIZE=4]deleted my Instagram account[/SIZE]
Thanks for offering such a helpful response, sustain sharing more knowledgeable content.
