I have a code segment
data_preprocess_segment_5 = df.apply(lambda x: ' '.join(segment(x)))
which takes a lot of time maybe more than 24hrs to process.
I was thinking to do
df[0:1000].apply(lambda x: ' '.join(segment(x)))
df[1000:2000].apply(lambda x: ' '.join(segment(x)))
df[2000:3000].apply(lambda x: ' '.join(segment(x)))
parallelly and later merge those df
