How to mount ISO as cd drive to you PC with Android.
[CENTER]
THIS GUIDE WILL ALLOW YOU TO MOUNT ISO WITHOUT ROOT, BUT ROOTED IS BETTER[/CENTER]
STEPS
[li]Download Drive Droid.[/li][li]Download an ISO file to begin with.[/li][li]Open Drive Droid APP.[/li][li]Click on wizard, it will guide you to setup the entire app.[/li][li]Be frank and answer wisely.. I recommend using Kernel Legacy.. If it does not works try others.[/li][li]Make sure that you PC is booting from cd drive we emulated. ( Drive droid will insert a test bootable disk)[/li][li]Don’t forget to ENJOY![/li][/ol]
If you are facing any issue, post down below… This app requires kernel to allow.. If its a config error, I will surely help you!
reserved for IMPROVEMENTS!
U can use z archiver to open iso in android
Bro… Not opening iso… Using ur android device as a optical drive.
WOW! Never knew that Android is this powerful!:eek:
I tried this but it won’t mount Windows 10 but it does mount DriveDroid’s test image.
So now im trying to make a bootable usb via Linux :slight_smile:
