I recently bought an Echo Dot and is loving it. I was wondering if i can use it to control my PC, like to play a movie, pause, shut down and all. Can it be done?
It should be possible as you can create alexa skills and program something for your pc but if coding is not your thing then im not sure
Well I’m not good with coding so does that mean I’m out of luck ?
Don’t worry just get right tools online and you won’t need any coding
Yes, you can use your Echo Dot to control your PC to some extent but It’s important to note that the level of control you can achieve will depend on the specific capabilities of your PC, the software you have installed, and the available integrations
it’s possible i feel saw someone doing it on youtube
You can do that with home assistant Alexa integration.
Ill give this a shot, also there is an alexa pc app but i dont think i can control the PC itself
This is the way, use homeass on pi
But thats needs extra hardware and configuration, i was think to use a software or something on my pc which give some controls via voice either on pc itself or via phone or other alexa devices
You’ll need to set up Alexa with compatible apps and software. For basic controls like shutting down, you can use Alexa’s “Windows PC” skill or third-party apps like VoiceBot or AutoHotkey to create custom commands for things like launching movies, pausing, or shutting down your PC.
