Lineage-OS[64bit][ROM][Oneplus 3/3T][STOCK CAMERA LIB]
 * Your warranty is... still valid?
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you.
ROM Features
=>Unified ROM for OnePlus 3/OnePlus 3T
Goal of this ROM
Lineage OS is a cyanogenmod based rom. Which is developed by the same team cyanogenmod. This rom aims at customizability with near to stock experience.
Known bugs
=> Tell me.
Recommendations
TWRP
TWRP 3.0.4-1 from https://forum.xda-developers.com/one…-3-3t-t3543391
Firmware
OnePlus 3: http://vps355909.ovh.net/firmware/On…3_firmware.zip
OnePlus 3T: http://vps355909.ovh.net/firmware/On…3_firmware.zip
File System
Use ext4 instead of f2fs, to reduce load time in TWRP.
Installation
  • Flash the latest TWRP version from the Recommendations section
  • Wipe your device through TWRP
  • Recommended Format /data as ext4 (f2fs is unstable at the moment)
  • Flash the latest firmware from the Recommendations section
  • Install the ROM from the download section below with TWRP
  • Install GApps, (ARM64, 7.1, I recommend stock but a different package should also work) (The Open GApps Project)
  • Boot your device.
Updating
  • Make a Nandroid backup
  • Check whether there’s a new TWRP release (from the Recommendations section) and in case flash it before going on
  • Check whether there’s a new firmware release (from the Recommendations section) and in case flash it before going on
  • Flash the ROM with TWRP
  • Wipe Dalvik / ART cache and Cache in TWRP
Download
lineage-14.1-20170225-UNOFFICIAL-oneplus3.zip | by Abhiram Shibu for One Plus 3
Source
www.github.com/lineageos
Credits
=> @Neeraj55#5
=> @Prasoon Mehra
=> Lineage TEAM
Download link published
[emoji12]
