Memory modules were found on non-optimized memory slot MSI B450 motherboard
[ATTACH type=“full” alt=“MVIMG_20201030_153553~2.jpg”]308[/ATTACH]
I got this warning after booting my new PC build. “Memory modules were found on non-optimized memory slot. Please follow instructions and move the yellow-marked memory modules to the arrow-marked optimized memory slots.”
This warning shows for a few seconds and boots, what should i do?
That’s simple mate, just move the ram sticks to the shown slots that’s all.
like, thanks you so much
Okay, moved them and now it’s all fine but I don’t feel any performance difference
You will feel a performance difference due to the way dual channel memory works. For dual channel configuration to work properly you should put your RAM stick in any of the 3 ways.
[li]For two sticks of RAM then put it in slots 1 & 3 or slots 2 &4.[/li][li]For three RAM sticks put them in 1, 2 & 3.[/li][li]If you have 4 sticks of RAM then it doesn’t matter putt them in any order :laughing:.[/li][/ul]
