Samsung galaxy j2 not booting.
My samsung galaxy j2 is not booting up. its only showing samsung logo and not working.
I cant enter the boot menu though.
Can i fix this?
How?
Try to factory reset from the recovery and if it still doesnt solve your issue then try to flash the stock ROM
Yep . I cannot enter into recovery mode ,
It just restarts whenever i try though.
So how do i flash rom with the help of a pc.
Go to Firmware download for Galaxy J2 SM-J200G and download the latest firmware for your phone and follow the below instructions.
[li]Download tested firmware or Odin flash tool from above link[/li][li]Extract to both files to desktop or as you like path ( must be installed winrar software in your computer or laptop)[/li][li]Open Odin3_v3.10.7 folder and choose Odin3 v3.10.7.exe file[/li][li]Click on BL button and choose BL_J200GDDU1AOI3_CL5713897_QB6186…tar.md5 file[/li][li]Click on AP button and choose AP_J200GDDU1AOI3_CL5713897_QB6186…tar.md5 file[/li][li]Click on CP button and choose CP_J200GDDU1AOI3_CL5713897_QB6186…tar.md5 file[/li][li]Click on CSC button and choose CSC_ODD_J200GODD1AOI3_CL5713897…tar.md5 file[/li][li]Turn Off device (if your device ON)[/li][li]Press and hold Volume Down + Home + Power button for Download Mode[/li][li]Insert usb cable into device (wait until driver installed)[/li][li]Click on Start button[/li][li]Wait until full installed Android system (note : do not try unplug when your device in download mode)[/li][/ul]
That’s all. [COLOR=rgb(226, 80, 65)]These steps apply for Samsung Galaxy J2 (J200G)
