Scan and Repair corrupt Windows system files with "sfc /scannow"
Recently I have been exiting from my CSGO game sessions and due to VAC issues and when I click ok it takes me to a steam support page (Disconnected by VAC: You cannot play on secure servers - Steam Support) where it shows various options to fix the issue.
And among the instructions provided there, I found the following cmd command [ICODE]sfc /scannow[/ICODE] to scan and repair Windows system files.
I typed in that code, then it scanned and said
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files and successfully repaired them.
For online repairs, details are included in the CBS log file located at
windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
repairs, details are included in the log file provided by the /OFFLOGFILE flag.
So what is this? I have installed my windows a few weeks ago and should I be worried?
You might be getting the error due to corruption issues in the steam client. So restart the steam client and check if the issue is solved.
[li]Open the Steam Client on your computer and click on the Steam located on the top left corner of the window.[/li][li]Click on the Exit option.[/li][li]Now, open the Steam Client again.[/li][li]Again, click on Steam and select Go Offline.[/li][li]Click on the RESTART IN OFFLINE MODE button.[/li][li]Again, click on Steam and choose the Go Online option.[/li][li]Click on the RESTART AND GO ONLINE button.[/li][/ul]
Try launching the game and check if the issue is resolved
Those steps work sometimes and that too temporarily. I tried uninstalling the game and reinstalled it, uninstalled steam reinstalled it, and even cleared all the files related to steam that I could find but still the same. I now reinstalled Windows and it’s okay now. But in this copy, I haven’t installed Logitech GHUB and ASUS Armory crate software. I highly suspect GHUB to cause that issue as it has some lighting effects and things that install an addon to the game.
