I was thinking about buying a room air cooler, the ones that use water for cooling. And I'm having a thought that whether it can damage any electronics in the room like laptops or desktops? Has anyone experienced such a problem?
But i have read online that it does increase the room humiditypr0ph3t You can use it , no problem with it, air cooler uses water to cool the air it wont humidify the air so no problem using electronics in air cooler room.
Air Cooler doesn't have that much humidifying power to damage devices so you can use , usage of devices in humidity like dense fog may affect devices, air cooler cant create that much humidityBut i have read online that it does increase the room humidity![]()
What for???Charcoal Briquettes
You can use charcoal briquates to get rid of humidity in your home.What for???
As long as you have windows open and room is not too cold.. like there is some metal which is below room temperature significantly, it won't affect. Just a note if turned off electroinics is somehow taken from somewhere cold into a room with high amount of humidity, then it will be a problem..I was thinking about buying a room air cooler, the ones that use water for cooling. And I'm having a thought that whether it can damage any electronics in the room like laptops or desktops? Has anyone experienced such a problem?
