Solved Chromium VAAPI (Intel) (Prebuilt) [14092020]
9,350
Source Code : https://aur.archlinux.org/packages/chromium-vaapi/
Binary File : https://abhiramshibu.tuxforums.com/archlinux/chromium-vaapi-85.0.4183.102-1-x86_64.pkg.tar.zst
CheckSUM MD5 : 35eb3698792cdd914c8f5431d375bb30
Instructions.
1) Download the binary file.
2) Use gui package manager or command "sudo pacman -U <pathToPackage>" to install the package.
3) Configure chromium to force enable hardware acceleration.
File ~/.config/chromium-flags.conf
Code:
--ignore-gpu-blacklist
--enable-gpu-rasterization
--enable-zero-copy
--use-gl=desktop
--enable-accelerated-video-decode
4) Start or restart chromium.
Disclaimer.
1) I am not responsible if something happens to your hardware, personally I am using this same binary file and there was no issues with it.
2) I will try my best to update the binary file, chromium does take a lot of time to build so I thought it would be nice if people just get a compiled version.
3) I do not own the source code or has any copyright over it. All the credits goes to the original maintainer.
4) Not tested in manjaro but I will add my remarks here after testing.
Test Results
  • Arch Linux [PASSED] [14092020]
  • Manjaro Linux [PENDING]
