If you are looking for a solution to remove duplicates from CSV files easily you can try the MacSonik CSV Duplicate Remover for Mac. This tool helps you to find and eliminate duplicates from multiple CSV files at once. Its smart preview option helps you to preview CSV files before removal. It is made with a simple GUI which makes it easy for both the technical and non-technical users. Moreover, this software is compatible with all versions of MacOS.
