Can i install a 64 bit version os on any cpu ?
Or does it matter which cpu you are using?
Yes its should support 64 bit instructions.Can i install a 64 bit version os on any cpu ?
Or does it matter which cpu you are using?![]()
In earlier days, days of celeron 1st gen. You had 32bit CPUS. Now most of all CPU are 64bit.Can i install a 64 bit version os on any cpu ?
