How can I merge Outlook PST folders into a single folder without using MS Outlook
alexanderdavid
Oct 20, 2023
8
200
PST files are personal data storage files that include Outlook data such as emails, contacts, calendars, tasks, and notes, among other things. You might want to combine multiple PST files into one without losing data or creating duplicates. To merge Outlook PST folders into a single folder without using MS Outlook, you must use third-party software that can combine multiple PST files into one. There are solutions available online, one of the most popular being Sametools PST Merge Software. You can use this program to combine Outlook data files into a new PST file without installing Outlook. It can combine Outlook emails, calendars, contacts, and notes, among other things. Outlook PST files from 2019, 2016, 2013, 2010, 2007, and prior versions can be combined with the software. It also makes combining ANSI, Unicode, archived, and password-protected Outlook PST files simple. Resultant PST files can be saved on the desktop in a convenient location by users
There are several methods for combining Outlook PST folders into a single folder without using MS Outlook. If you wish to combine several Outlook PST folders into a single PST file without using MS Outlook, you'll need third-party software that can merge PST files from multiple folders. There are several such programs available online, but you should exercise caution when choosing one that is reliable and secure. To combine PST files, use the Outlook PST combine application, which is a simple and trustworthy tool that can merge several Outlook PST folders into a single PST folder without deleting the original PST folders. Among other things, it can merge Outlook emails, calendars, contacts, and notes. PST files from Outlook 2003, 2007, 2010, 2016, and previous versions can be integrated with the program. It also simplifies the process of integrating ANSI, Unicode, archived, and password-protected Outlook PST files. Users can save the resulting PST files on their desktops in a handy location.
