Here I will discuss two solutions to extract OLM file attachments first will be the manual solution to extract OLM email attachments, but users cannot perform this application safely without technical knowledge. skills and the manual solution is longer and more complicated to understand the process normally.
Manual Solution
Step 1: Configure and launch Microsoft Outlook on your Mac system.
Step 2: Add the OLM file using File Explorer.
Step 3: Choose the OLM file to extract and press the Next button.
Step 4: Choose the OLM data file and submit it to the next action.
Step 5: Choose which folder to extract, a single folder or all email inboxes.
Step 6: Determine where you want to store the saved Mac Outlook OLM file.
Step 7: Click Finish. After that, users must repeat the process to extract further OLM attachments.
Technical Solution
Here I am going to suggest a safe and instant solution to extract OLM attachments from Outlook from Mac, then you should try The best solution is The Softaken OLM Attachment Extraction Software, which preserves any data viewed by numerous users. Users can quickly extract OLM attachments if they want to extract OLM emails from Mac Outlook. This software can quickly extract all OLM email attachments without affecting the original content. Extract different attachments such as documents, text, PDF, gifs, PNG and. With ease, this utility can handle any Mac Outlook file including those from 2021, 2019, 2016, 2013, 2010, 2007, 2003, etc. attachment, and saves it to the designated location with a few clicks, and the OLM attachment file Users can download this application on their Windows operating systems.
Follow these steps to extract OLM attachments
1 step: Install this tool on your system
2 steps: Add OLM file Mac Outlook
3 steps: Open and select the OLM attachments to download
4 step: Select the option to extract attachments from a file or folder
5 step: Tap the Browse button to select a location to save the files.
6 step: Tap the process button to start the process.
Manual Solution
Technical Solution
