How to view corrupted OST files with Kernel OST Viewer tool?
shivgupta
Nov 1, 2023
25
1,700
The Kernel OST Viewer tool is designed to help you view the contents of corrupted OST files. Here's a step-by-step guide on how to use it:
  1. Download and Install Kernel OST Viewer:
    • Visit the official Kernel website or a trusted software download platform.
    • Download the Kernel OST Viewer tool.
    • Install the tool on your computer by following the on-screen instructions.
  2. Launch the Kernel OST Viewer:
    • Open the installed application on your computer.
  3. Select Corrupted OST File:
    • In the tool's interface, click on the "Browse" or "Open" button to select the corrupted OST file you want to view.
  4. Scan and Preview OST File Contents:
    • Once you've selected the OST file, the tool will start scanning the file for its contents.
    • After the scanning process is complete, the tool will display a preview of the items within the OST file, including emails, attachments, contacts, etc.
  5. Navigate and View Items:
    • Use the navigation options within the tool to explore the contents of the OST file.
    • You can view emails, attachments, contacts, and other items directly within the tool's interface.
  6. Advanced Search and Filter Options:
    • Take advantage of advanced search and filter options provided by the Kernel OST Viewer to locate specific items quickly.
  7. Export if Needed:
    • If you want to save specific items or the entire OST file, check if the Kernel OST Viewer provides any export options. Some viewers allow you to export items in various formats.
  8. Close the Viewer:
    • Once you have viewed the necessary information, close the Kernel OST Viewer tool.
You can view your corrupted OST file in two different ways. Here are some ways to view corrupted OST files.
Manual method:
You can use the manual method to view or recover corrupted OST files. However, this method was not recommended by many users because, with it, there is no assurance that all of your OST file data can be recovered, and there are also some risks and limitations, such as.
  • limitation of the OST file size
  • The recovery process was time-consuming.
  • Complexity of steps
  • Risk of data loss
  • And many more
Utilizing third-party software:
You can use third-party software to view corrupted OST files. You might try Softaken OST Repair Software to recover or view corrupted OST files. The tool saves you lots of time and recovers your OST file in a few simple steps.
  • Install the OST repair program.
  • Select either file or folder mode to browse the OST file.
  • Select the desired items from the OST file recovery.
  • Choose the file format in which you wish to export the restored data.
  • Use the browse button to specify the place.
  • Click the Convert button.
Also, the application supports all MS Windows editions, such as 7, 8, 8.1, 10, and all other variants. You can also check out the free demo version of this software to learn more about its features.
Read more:
https://www.softakensoftware.com/ost-repair.html
Firstly, you need to repair your corrupted OST file, then you can view your OST file. To repair a corrupted OST file, you can use third-party software rather than the manual method, because with the manual method there are lots of limitations or restrictions. So, you can utilize ToolsBaer OST to PST Conversion Software to recover or convert an OST file. You can easily retrieve all of your data with the use of this application. You can save their data to a location of your choosing while the application restores it. Without any issues, the utility can restore OST files of any size. Every Microsoft Windows version is compatible with it. To find out more, you can also install the trial version of the utility. know more: https://www.toolsbaer.com/ost-to-pst-conversion/
The Aryson OST Viewer software enables users to easily open, view, and save OST files in various formats, including PDF, DOC, HTML, and CSV, while preserving attachments. It allows for viewing OST file contents without Outlook and offers the flexibility to save OST files in formats like PST, EML, MSG, MBOX, and EMLX. Additionally, the software supports opening OST files in Outlook 2019 and earlier versions, as well as importing OST files into different email clients, such as Office 365, using the OST to PST Converter Tool. This versatile software is compatible with both Windows and Mac OS X operating systems.
