If you want to activate USA network on your Android TV then you must follow the steps that are given below:-
- The inital step is to turn on your Android TV and then open the play store.
- Now search for the USA Network app and install it.
- Then note down the activation code that appears on the display.
- Now open the browser on any other device like smartphone and then visit usa network.com/activatenbcu.
- Then enter the code in the respective field and select your TV provider.
- Now finally click on the Continue button.
