[ROM][VoLTE][OMS] || Tipsy - OS || [7.1.1 r_9][14 Feb]
Neeraj55#5
Feb 24, 2017
29
1,850
✯ ✯ ✯ TEAM DESTROYER PRESENTS ✯ ✯ ✯
WARNING !!!!!!!
YOU
ARE
ABOUT
TO
GET
https%3A%2F%2Flh3.googleusercontent.com%2FzZj23chx8-rGi3dTr9-HDyUBGTYq3YZLmdOruOT9KXVhk0asiHD02xq5G88QFOM1m-AkBRlG77Zkokm6U9WJvSZw05ToH6s-6MWyYxYI4WnJzg2jtHhuOSpM91auNv6WlSNgZbahT-hUIPaXAWboXGDwLQA3BqI7LVXlXvmjxyb8Xwhjryr-qkp9WaUd1WsZvDlN7HkHLnkc6AmM40TfZvFd2TWWOYLoRLfJFDWPYYafrqJlnIyrC-Kfvf5wLEe42JRwGC9G8EoXnm5lIfuU5UfIKTBhTjxML2-zer1RTW3W2F-Qs9fEpOBNXLvqSOj6RoYT9j5UEqiVHSrZzs4vEFoJ5xFCAs5nPoaVsD2Z9M01Z-penGwawqioaG8pke9__VDmxCQCV4sk5nU2T4VAKbM1PNEsddLqRBuZmpBINVM_mm1btUZqJiZk8Ic5VHCgNLt4gxOdkFKg6onJBfdPpMPMp_DpZM4J6w4wmdVcJ3aycuImN5KpRtUvKorlBdJYg6svqEnftzjui_Sp_IvHe-rcFOvYiVUkqBH0aM_BRiBynXIHoc1dDfy6dp4il5Vpsn-K-dL6SsO8cRs_r5ttut1jsZN0Bk0%3Ds653-no
TipsyOS is Black and Yellow default themed, we don't like white UI, so it may look a bit weird on light switch,
One, try it and feel speed and stability
Features :
"The Tavern"
    • Power menu customizations
    • Toasts/ListView/System animations
    • Battery bar
    • LCD Density
    • Gesture Anywhere
    • Expanded Desktop
    • Status bar customizations
    • Aosp Recent and OmniSwitch
    • Built in:
    • Dashboard (settings) columns selector
    • Dashboard lines remover
    • Slim Navbar customization
    • Volume steps
    • Notification led changer
    • HeadsUp switch
    • Kernel Adiutor app
    • Substratum
    • Adaway
    • Nova launcher
    • Viper4Android
    • SnapCam
    • Changelog generator in about phone menu....
Download :
Tipsy-OS 14 Feb
ES File Explorer[As there is no File explorer yet in ROM]
OpenGApps
SuperSU
Installation instructions :
    • Download the ROM.
    • Reboot to recovery.
    • Wipe system/data/cache partitions
    • Flash the ROM.
    • Flash 7.x GApps.
    • Flash ES File Explorer zip [ES.zip]
    • Reboot and feel Tipsy!
Source :
Tipsy-OS : https://github.com/tipsyos
Kernel :https://github.com/CyanogenMod/android_kernel_cyanogen_msm8916
Bugs :
    • Brightness can't be adjusted [Use some apps like screen filter or the one u know :D]
    • Hardware Keys Don't Light Up
    • You tell me :cool:
✯ ✯ ✯TEAM DESTROYER✯ ✯ ✯
Neeraj55#5
Feb 24, 2017
29
1,850
How to get VoLTE working:
  1. Download Modem from link below
  2. Extract the zip.
  3. Reboot the phone to fastboot mode.
  4. Open the folder with VOLTE modem. Press alt + shift + right click and click on open command window here.
  5. Enter the code :
    Code:
    fastboot -i 0x1ebf flash modem NON-HLOS.bin
  6. Press Enter
  7. This will flash the modem files.
  8. When it says OK disconnect the phone and reboot.
  9. Enjoy
Downloads :- VOLTE MODEM
Vams
Feb 27, 2017
19
1,650
My Inital Impressions :
"Fast like Supersonic Jet" quoted by Abhiram Shibu Abhiram Shibu is 100% true
But im not happy with the build as i encountered some bugs and they are listed below
1. Hardware Button control Missing
2. slim recent not working
uploading some screenshots
