Alongside Asian Handicap and European Handicap, Over/Under betting is a crucial type of bet in every betting market. Despite its popularity, many people still don't fully understand these odds. Let's explore how to read and analyze Over/Under odds in detail with win bet tips through the following article!
Place an over bet when you predict that the total goals scored by both teams will exceed the Over/Under odds.
Conversely, place an under bet when you predict that the total goals scored by both teams will be less than the Over/Under odds.
Over/Under bets are only valid for the 90 minutes of regular play plus stoppage time, excluding extra time and penalty shootouts, so players need to be mindful of this.
Over/under corner kicks
Over/under corner kicks is a type of corner kick bet where the bookmaker will provide the number of corner kicks that will occur in the match. Players' task is to predict whether the actual number of corner kicks will be less than or greater than the bookmaker's number by placing bets on Over or Under.
Over/under yellow cards
Similar to over/under corner kicks, over/under yellow cards is also a side bet. In this type of bet, players predict whether the number of yellow and red cards shown in the match will be higher or lower than the bookmaker's over/under odds. If it's higher, choose over; if it's lower, choose under.
To avoid confusion among the various over/under odds, free hot football tips will guide you on how to read popular Over/Under betting options in football:
Over/Under 0.5/1
Also known as over/under 0.75 or over/under ¾, it's read as follows:
Bet on over wins when the total goals scored are >=2.
Both over and under bets push when the total goals scored = 1.
Bet on under wins when the score is 0-0.
Over/Under 1/1.5
For over, win the bet when total goals scored >= 2, lose half the stake when total goals scored = 1, and lose the full stake when total goals scored < 1.
Conversely, for under, win the bet when total goals scored < 1, win half the stake when total goals scored = 1, and lose the full stake when total goals scored >= 2.
Over/Under 1.5
If total goals scored are 2 or more, bettors who choose Over win, those who choose Under lose.
Conversely, if total goals scored are less than 2, bettors who choose Over lose, while those who choose Under win.
Over/Under 1.5/2
This is also written on the betting board as 1.5-2 or 1.75, and is calculated as follows:
Betting on Over wins, betting on Under loses when total goals scored >= 3.
Neither bet loses when total goals scored = 2.
Betting on Over loses, betting on Under wins when total goals scored are 0 or 1.
Over/Under 2.5
Similar to the 1.5 level, the win-loss determination for over/under 2.5 is as follows:
Also referred to as 2.5-3 or 2.75, regardless of how it's written, the win-loss determination is as follows:
Bet on Over wins when total goals scored >= 4, push when total goals scored = 3, and lose the bet when total goals scored <= 2. Conversely, bet on Under wins when total goals scored <= 2, push when total goals scored = 3, and lose the bet when total goals scored >= 4.
Over/Under 3/3.5
If total goals scored by both teams >= 4, betting on Over wins, betting on Under loses.
If total goals scored = 3, betting on Over loses half the stake, betting on Under wins half the stake.
If total goals scored are 0, 1, or 2, betting on Over loses, betting on Under wins.
Winning amount = odds x bet amount
Amount received when winning half the bet = (odds x bet amount) / 2
Amount lost when losing half the bet = bet amount / 2
Amount lost in case of losing the bet = Bet amount
How to analyze over/under betting odds for today's and tomorrow's football matches to ensure winning
To ensure winning when betting on over/under, players need to equip themselves with strategies to analyze and best football prediction app over/under bets effectively:
Choose suitable matches: Players should prioritize selecting matches they are familiar with or have ample information about from reputable online football platforms. Experienced bettors advise that not every match is suitable for placing over/under bets. Therefore, it's essential to choose matches where both teams have comparable strengths, especially prioritizing hot matches or those from major football leagues worldwide such as the World Cup, Euro, La Liga, Premier League, etc. This helps bettors have more useful information and football insights to aid in analyzing the odds.
Analyze the two teams: After selecting suitable matches, the next crucial factor in determining whether you win the over/under bet is analyzing the strengths and weaknesses of both teams. This helps bettors accurately assess the match's outcome. Therefore, before making betting choices, players need to thoroughly research some basic factors such as the expected starting lineup, which team has more goal-scoring prowess, playing style, recent performance in the last 5 matches, ranking, advantages, etc.
Regularly observe the betting board: Depending on the timing, over/under odds on the betting board will fluctuate differently. Typically, these odds change within about 4 – 5 hours and about 30 minutes before the match begins. Therefore, players need to frequently monitor odds fluctuations to make the most rational choices and avoid falling into bookmakers' traps.
Over stuffing over technique: With this method, players choose to bet over from the start for matches where the over/under odds are not high. Then, if the over/under odds decrease during the match, players will continue to place another over bet. This method is suitable for matches where both teams have weak defenses or one weak team faces a team with a strong attacking force. It's recommended to lower the over bet between the 12th and 59th minutes of the match. This technique is applicable to leagues featuring teams like Germany, France, Italy, the Netherlands, etc., but not suitable for matches in the English Premier League or the Champions League as the teams in these leagues usually have evenly matched strengths.
Under stuffing under technique: In contrast to the over stuffing technique, players select under from the start for matches where the total number of goals is likely to lean towards under. During the match, try to seize the moment when goals are scored to place another under bet. This method is applied when the match involves a team with a good defense against a team with weak attack, or when the focus is not on winning or losing, and the number of goals scored is minimal. This technique also suits matches where both teams have strong defenses, history shows few goals scored between the two teams, or it's a friendly match.
Winning tips from experts:
Over/under betting is what?
Over/Under betting, also known as O/U, is a popular type of football betting. In this type of bet, players predict the total number of goals scored in a match by placing bets on over or under, based on the number provided by the bookmaker.Place an over bet when you predict that the total goals scored by both teams will exceed the Over/Under odds.
How to play popular over/under betting types nowadays
In addition to the commonly seen over/under total goals bet, players can also wager on other types of over/under bets, including:Over/under corner kicks
How to read standard over/under football betting odds
Over/Under 0.5/1
- If the total goals scored are 2 or more, betting on over wins, betting on under loses.
- If the total goals scored are exactly 1, over wins half the stake, under loses half the stake.
- If both teams don't score any goals, under wins, over loses.
Over/Under 1/1.5
Over/Under 1.5
Over/Under 1.5/2
- If the total goals scored by both teams are > 3, betting on Over wins, betting on Under loses.
- If the total goals scored by both teams = 2, betting on Over wins half the stake, betting on Under loses half the stake.
- If the total goals scored by both teams < 1, betting on Over loses, betting on Under wins.
Over/Under 2.5
- If total goals scored >= 3, betting on Over wins, betting on Under loses.
- If total goals scored are 0, 1, or 2, betting on Over loses, betting on Under wins.
- If total goals scored by both teams >= 4, betting on Over wins, betting on Under loses.
- If total goals scored by both teams = 3, betting on Over loses half the stake, betting on Under wins half the stake.
- If total goals scored by both teams <= 2, betting on Over loses, betting on Under wins.
Over/Under 3/3.5
Guide on how to calculate over/under in live football betting
Although there are many over/under betting odds, they all have the same payout calculation method. Here is the general formula for bettors to refer to:Winning amount = odds x bet amount
To ensure winning when betting on over/under, players need to equip themselves with strategies to analyze and best football prediction app over/under bets effectively:Choose suitable matches: Players should prioritize selecting matches they are familiar with or have ample information about from reputable online football platforms. Experienced bettors advise that not every match is suitable for placing over/under bets. Therefore, it's essential to choose matches where both teams have comparable strengths, especially prioritizing hot matches or those from major football leagues worldwide such as the World Cup, Euro, La Liga, Premier League, etc. This helps bettors have more useful information and football insights to aid in analyzing the odds.
- Place bets around 10 minutes after the match starts. During this time, the over/under odds tend to decrease, increasing the chances of placing favorable bets.
- Bet over when a team has a high scoring record. Conversely, bet under when teams have a goal-scoring efficiency of less than 1 goal.
- If there are no goals in the first half, there's a high probability of goals being scored in the second half.
- For beginners, it's advisable not to bet too much money solely relying on luck. Instead, learn thoroughly about analyzing over/under odds, studying both teams' situations, and gathering betting experiences to make the most accurate choices.
