I live in the UK and use the Carrier GiffGaff, a subsiduary of O2. The issue is that I plan on purchacing a new phone and would like to use 4G/LTE. The frequency band O2 uses is 800 MHz though which two of the phones in consideration do not support.
http://www.gsmarena.com/compare.php3?idPhone1=8291&idPhone2=8263&idPhone3=4664
http://www.4g.co.uk/4g-frequencies-uk-need-know/
Phones in consideration:
Xiaomi Redmi Note 4
Xiaomi Redmi 4 Prime
Elephone P9000
The question is: Even though the phones don't support the Band 20 , can it connect to other carriers cell towers using a different band and therefore enable me to use 4G?
Or would I only be able to use 3G?
If you have other recommenations or advice please do post your opinion.
Thank you
Xiaomi Redmi Note 4
Elephone P9000
Thank you
