Best Monitor For Valorant?
If anyone wants to buy a monitor but doesn’t know which monitor is good for valorant. I suggest you buy from these four:
  1. BenQ Zowie XL2546 24.5′′ 240Hz
  2. Alienware 25
  3. BenQ ZOWIE XL2411P, 24′′ 144Hz
  4. Acer Predator XB241H 24″
Or if you want to know these in detail, you may check the whole article about the best monitor for valorant on my website.
What do you think about Dell Alienware Gaming Monitor for Valorant?
Of course, It will be better as it’s 240hz but if you go for good looking then Acer Predator XB241H 24″ will be better. But for gaming, I always suggest a higher refresh rate monitor(if you have the budget) and when it comes to valorant, you must have to
