Does frame rates higher than 144 make any difference?
Does anyone really notice a difference when it gets higher than 144hz and if so dose it really matter while playing a game?
Yeah it does when make a difference when playing games like CSGO. It does makes a difference that’s why Asus made a 360Hz monitor.
I think that coming from 60 FPS to 144 FPS is a huge difference! Anything over 144 FPS isnt a big difference but makes the games looks more smoother.
over 144Hz is not a big difference but it might improve frametimes.
holy crap 360Hz. is there even a game that could get that high
Yeah there are many games. CSGO can easily achieve that much fps.
oh i dont play multiplayer games. by the way is the cat smoking??
https://www.youtube.com/watch?v=Pf_k8Lg4dmo
Yes he is ?
damn 500 thats more than half of what i spent on my computer
okay i was just wondering cause i was thinking of getting a new monitor and wanted to see some opinions
Then buy this one! “BLEEDING EDGE” idk if its available to buy now.
For the average consumer, no, those extra 100 FPS aren’t going to make you a better player or have more joy in the game. .
Yes- if you have experienced higher framerates.
NO- If you havent experienced higher framerates.
Higher framerates generally costs you the display quality. Please see the display in person and then buy.
This is actually true. Some panels are even overclocked and sold. For those panels, the image becomes much much softer than the lower framerate output
Yes, If you run a game at 60 fps on a 144hz monitor it won’t feel smoother than games running at 60fps on a 60hz monitor. So 144hz will not be beneficial in games if you don’t have capable hardware to deliver those levels of frame rates.
Of course, it is!! Also, there are many high refresh rate monitors which will help you to improve your performance. And a game like valorant, it’s really effective.
I have monitor with 240 Hz but didn’t find any major difference. Instead of getting over 144hz improve in resolution to 2k
