4K or higher frames
So as games come out would you rather see them push the resolution or framerates
I think that is an age old question, that depends on what you want.
Do you want high response time or do you want high quality.
If you are competitive gamer, you will choose response time over quality of gameplay.
frame rates, up to 144 fps then push resolution
can i pick improving story
It depends on whether you already have a monitor of more than 60hz, sincerely the 4K is noticeable in monitors of larger inches and depending on the distance, do not test more than 60hz, there I can not comment
Honestly i’ve never experienced life above 60fps so I guess resolution? But even then i’ve lived with 1080p and never had a complaint. Games can already be made to look amazing. Games just need to get better!
If you’re someone that enjoys single-player titles, like massive open-world RPGs or packed urban cityscapes, then a high resolution may be the most suitable choice for you. While the frame rate is still relevant, a solid 60 FPS is all you need for an delightful visual experience.
