I want to build a new PC help me choosing components
I want to build a pc that can play games(1440p ultra if possible), stream games, video editing etc
My budget is 150000 Indian Rupees including keyboard(mechanical) monitor(1440p), mouse headphone(gaming)
I dont care about RGB i want to spend my money on perfomance not on looks
Please dont use PC partpicker site coz it shows wrong price in india.
Processor :
AMD RYZEN 2800X - https://www.amazon.in/dp/B07B428M7F/?tag=tuxforums-21
OR
Intel Core i7 8700K - https://www.amazon.in/dp/B07598VZR8/?tag=tuxforums-21
32 GB RAM KIT Corsair 16x2 - https://www.amazon.in/dp/B0134EU9YA/?tag=tuxforums-21
OR
32 GB RAM KIT Kingston 8x4 - https://www.amazon.in/dp/B00TPQPUPK/?tag=tuxforums-21
OR
16GB KIT
MB ASUS ROG for AMD AM4+ - https://www.amazon.in/dp/B071ZHCF41/?tag=tuxforums-21
OR
MB ASUS ROG for AMD AM4+ - https://www.amazon.in/dp/B072C6VPZJ/?tag=tuxforums-21
OR
MB MSI for Intel K series - https://www.amazon.in/dp/B075GN9YC4/?tag=tuxforums-21
OR
MB GIGABYTE for Intel K series - https://www.amazon.in/dp/B075KFX627/?tag=tuxforums-21
SMPS COOLER MASTER 550W - https://www.amazon.in/dp/B07C5P7B4N/?tag=tuxforums-21
OR
SMPS CORSAIR VS550 550W - https://www.amazon.in/dp/B00DQ5OB4C/?tag=tuxforums-21 (Mine failed [rebooting in ups with pwr failure and pc not able to turn on CPU] and bought Cooler Master)
MONITOR ACER 144FPS - https://www.amazon.in/dp/B06ZYHZ6R6/?tag=tuxforums-21
OR
Check others for your taste.
KEYBOARD Logitech - https://www.amazon.in/dp/B06XR5MWGM/?tag=tuxforums-21
OR
Gofor corsair but will be expensive.
MOUSE Logitech MX Master - https://www.amazon.in/dp/B071YZJ1G1/?tag=tuxforums-21
OR
Gofor something which you are comfortable with… and has a high DPI (adjustable preferred).
When you are going for gaming, RGB is inevitable.
If you cut short on RAM, MB and Case - you can buy a GTX 1070 - https://www.amazon.in/dp/B01GXOX2BU/?tag=tuxforums-21
OR
GTX 1060 6GB - https://www.amazon.in/dp/B01IMZTEBK/?tag=tuxforums-21
My use case is totally different. Mine requires a badass GPU and CPU, if yours does not need that, you can cut short on CPU.
Please select SSD or HDD as per your preference. I recommend NVME but its quite expensive, even SATA ssd will make a big difference. Check if SSD has MLC flash and a good controller for better write endurance.
I hope this helps you… This is not a sponsored or affiliate link… I just kinda found everything in amazon.
