For all the gamers out there who are looking to build a budget 1080p gaming PC then this is for you!
[INDENT][SIZE=5]Parts List:[/SIZE][/INDENT]
[li]CPU: Intel Core i5 6402p [ Buy from Amazon][/li][li]Motherboard: Gigabyte H110M S2 [ Buy from Amazon][/li][li]RAM: Corsair Vengeance 8GB [ Buy from Amazon][/li][li]Video card: Zotac GTX 1060 3GB [ Buy from Amazon][/li][li]Case: Corsair 100r [ Buy from Amazon][/li][li]PSU: Corsair VS450 [ Buy from Amazon][/li][li]Storage HDD: Toshiba 1TB [ Buy from Amazon][/li][li]Storage SSD: Samsung 750 120GB SSD [ Buy from Amazon][/li][/ul]
Max Price: $779, Pricing may vary according to your location.
Notes: For this budget, this is a perfect Intel PC for gaming. You can change the Harddisk and increase the SSD size according to your wish. If you have more to invest then I would recommend choosing different motherboard like [SIZE=4]MSI H110M GRENADE.
[/SIZE]
[SIZE=5]Benchmarks[/SIZE][SIZE=4]:
Counter-Strike:Global Offensive at High setting in 1080p:
Min FPS: 104
Max FPS: 278
Crysis 3 at Hight setting in 1080p:
Min FPS: 39
Max FPS: 114
GTA V at V.HIGH setting in 1080p:
FPS: 70-110
Rise of The Tomb Raider at V.HIGHT setting in 1080p:[/SIZE]
Average FPS: 54
Battlefield 1at HIGHT setting in 1080p:
Min FPS: 72
Max FPS: 110
3D Mark Score:
3674 in TimeSpy
9440 in FireStrike
[SIZE=4]Unigine Heaven Benchmark 4.0:
FPS: 58
Score: 1507
Min FPS: 9
Max FPS: 124
[/SIZE]
[CENTER]This PC can easily run most modern games in Full HD. Please rate and reply![/CENTER]
