How is this build?.
I have been trying to build a good gaming PC under $600 .
Are these specs good ?. And most importantly , for how long will this PC be able to run AAA games on high settings @30-40 FPS?.
EDIT : Can this PC be called a ‘Console Killer’ in any way?.
https://linustechtips.com/main/uploads/monthly_2018_02/5a94382b73ef1_Screenshot_20180226-2137313.png.cbd517eee3902a8adeb20723c9154fd0.png
Never!
The CPU and GPU of your choice will never beat current gen consoles. 1050Ti is basically 750Ti or steroids! I have one and i can only give me 40 to 45FPS on GTA V :frowning: on max setting at resolution 1600x900.o_O
Ryzen 1400 or above will be a better choice. :slight_smile: And 8GB or more RAM is needed to gaming or for common use today.
1050Ti :frowning: and 8GB RAM :confused: won’t give good gaming experience. Rest is good but not a console killer yet.
If you are looking to build a good gaming PC under $600 then check this thread #Pancake - $600 Ryzen 5 build. .
8Gb of memory would be adequate for your system 4Gb is a bit lesser. With this type of rig, you can easily play current games on medium/high settings.
8GB of RAM is now the recommended minimum.
